Defnitely nice to have swype back without having to re-select the keyboard after each reboot. The new version is working well for me.
Swype | Text Input for Screens is the only place you'll see posted here. App piracy is frowned upon and posting links to, or asking for, pirated apps can get a thread closed pretty darn quick.IS there a working download of this somewhere? The link on Droidlife leads to a nonworking version.
same with me. I always forget my email or password.yeah, but i never remember my password so i usually end up dl twice
like today
I prefer the older version. It has a much cleaner and more attractive appearance, IMO, and it has a couple dozen languages available, whereas this one has 5 or so. I'm reverting back.
So I tried to login to my swype account to reload beta. Well it kept saying that my password was wrong, even though I'm 100% positive it wasnt. So I clicked forgot my password, then the message comes up that they emailed me a new temp password. So I go to my email and it says thank you for registering with swype beta, we will let you know when beta reopens. LAME
Mine still needs fixed after reboots!
Any keybooard installed on your device (including the stock keyboard that shipped with it) can do this. Swype works closely with all the phone manufacturers and Google as well. I'm relatively confident you can sleep easy knowing you have their product installed on your device.Thanks im using it now. I like the keyboard but I don't like that it can track keystrokes.i think I will keep it for a bit but I hope my passwords don't end up getting stolen!
You couldn't have had a bug free version after installing Froyo. The issue you describe is/was a known issue with Froyo BEFORE the latest update. The latest update corrected that issue.It was working fine on my phone after installing froyo, but after installing the new beta I now have the problem of swype not working correctly after a reboot. I also have to turn it off and back on to get it to work right.
Went through the whole install and AGAIN it says it is installing, then Lookout says its safe.....but once AGAIN the tab to OPEN swype never highlights. GRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
