Hi,
does it have 5.1 sound ? I mean it has an optical SPDIF out, right? So is there any video player software for Android what can play 5.1 sound through it to my amplifier? (it has no HDMI input)
thx
Have fun with it.
Greetings Paincake
It's much better then the stock rom. If you have the described box give it a try and let me know.
Edit: Works with SD Card - no cable needed
Didn't it work with the stock rom? I had it first running wireless (wpa2, aes psk) but had problems. Sometimes it disconnected for no reason and connected only after reboot. I'm not sure if I'm the only one with this problem.
Since that time I used it wired and never tried it again.
I'm trying it wireless for you now.
I have static ip settings so i can connect more easy to webkey and control it from my phone.
After 5 min of working wireless it stopped as usual...
Does anyone else with the same settings has this problem too?
I think it's a driver problem because the 3 roms i tried before all have the same problem.
