hmm this root looks very nice... maybe i also ty this one
is there anyone with the same problem i have regarding 2.4Ghz keyboard with touchpad? :
http://androidforums.com/google-tv/413090-r-box-rockchip-2918-google-tv-4.html#post4080075
Firmware is good, but on my CRT 4:3 tv set screen output is little distorted because initially box sets 16:9 aspect ratio. On previous firmware TV output used native TV resolution 768x576 pixels. Is there any way to change this?Hello all there sorry for my english i removed some apps from the firmware and now i have more ram mamory and more speed it's much more stable
deleted apps: gmail, facebook, ,himsn, netflix, games, twiter. talk. gboxlauncher and more.... installed adw launcher ex
to update use RKBatchTool and usb male/male
Download : g-box 11-3-2012.img download
[/URL]![]()
[/URL]![]()
[/URL]![]()
Hi everyone,
So I finally received my male to male usb cable connected the box to my laptop and nothing happens. Help????
BTW I know my box is bricked because I connect it to my tv and there is no signal there.
Please help!!!!!
Using Rkbatchtool, you push the recovery button near the power cable, and then you connect the power cable to the unit. Then windows will recognize the unit, and you will be able to load a image file. I suggest you to use the image created for Xzer0.
Hi Bangalter,
I tried that but nothing happened. I turned off, pushed the little whole on the back of the box, turned it back on connected to the laptop and nothing. My laptop seems to not detect the box what so ever. Any specific order that I need to do this?
Cheers,
Gus.
You shouldn't do this pushing the power button. Instead, you should unplug and plug the power cord. Please, try this way.
Hi Bangalter,
thanks so much!!!! my laptop finally recognised the box but now there is no way it will install a driver for it. I am running windows 7 :S
What's next?
Cheers,
Gus.
I am downloading the fw now.....
I got my box to work again. Thank you for your help Bangalter!
I have installed the firmware published by Xzer0 and found some glitches as follow:
1 - When I installed and uninstalled some apps the size of the icons on the screen go from good size to really really small.
2 - The browser crashes after 1, 2, or 3 big bang theory episodes from Watch Series Online for free, Full episodes - Watch Series. ( I know there is nothing to do with the Big Bang Theory but I am just listing what was happening at the time)
3 - Google search does not work.
Extras:
My camera still does not work, any idea on this?
Nevertheless, I am enjoying testing this fw
I am looking for a freeview dongle for android (for this box) I have found a few but all of them seem to have drivers only for windows. It would be great if we can find something that works for this box.
on my g-box works all good try update again the g-box und before you update delete all old maps from android apps und system
Hi there, what do you mean by old maps?
Cheers,
Gus.
[IMG][IMG]
Download : [URL="http://www.2shared.com/file/Y7W5dgLG/g-box_11-3-2012.html"]g-box 11-3-2012.img download[/URL][/QUOTE]
Hey xzer0! Thanks for your contribution.
Is there a way to update it with a SD card?
you can change the resolution in the box settings - display mine is 1280x720p-60
