Hi,
Have you selected the google calendars in the settings menu of the HTC Calendar application? There will usually be a few options including HTC Sync, Google, My calendar. Make sure only the Google Calendar is selected. Then check your sync settings to see how often the phone is syncing the calendar. Hope that helps...
Cheers
Shane
