Help G-sensor Calibrations Issues
wonj
Has anybody come across an issue when trying to calibrate the G-sensor? I have tried calibrating the G-sensor on a level surface twice, and both times the phone would not respond when I tried using the landscape mode. It gets stuck in the landscape mode and will not return to normal mode. Both times a factory reset was required to get it working again.
had the same issue, but my fix was to uninstall a level app I had installed
