G2 and sim card
lkosova
So my friendly UPS guy would not leave my phones at my door since he knew the goodness inside the box......going tommorow morning to get the G2 and Vibrant.
I am reading about the sim card not being the same that I have on my G1???
So....do I just use my old sim card or transfer that data to a computer and transfer back to the g2???
I have apps ,pictures etc on the sim card so just need some advice on what to do.
Thanks,
Larry
You aren't storing any apps or pictures on your SIM card. You probably meant SD card?
In either case, yes, they'll work in the G2. FYI the G2 comes with an 8GB microSD card already, so if that's bigger than your current one, you'll probably want to transfer all your data to it via computer anyways.
