daleoffret
I have a rooted MyTouch 3G (G2) phone that is rooted with CM-4.0.3.1. I want to move my applications onto my sd card with the built-in Apps2sd support.
I can't find any way to format my 8 GB Transend Class 6 sdhc card. ADB shell failed on Windows Server 2003 x86 and Windows XP using the Android SDK 1.5r3. Failed to partition using an Ubuntu workstation with the 'parted' utility.
Can I someone tell me what I am doing wrong or point me in the right direction? Can I send my SDHC card to someone to format for me with fat32/ext3/linux-swap?
1.) Model Number ? T-Mobile myTouch #G
2.) Firmware Version ? 1.5
3.) Baseband Version ? 62.50S.20.17U_2.22.19.26I
4.) Kernel Version ? 2.6.29.6-cm4 share@toxygene
4.5) Mod Version ? CyanogenMod-4.0.3.1
5.) Build Number ? COC10
Also do you have a T-Mobile Data plan on your
PayAsYouGo or FlexPay Plan? Yes
Carrier ? Tmobile
Country you are using your phone in ? US
Carrier ? Tmobile
