Help g2x questions
Hi, any help on these questions would be great :D
Well, i got CM7 onto my phone, but instead of having my 4G, it says H
I know H is like fast 3G, but, it doesn't work!
I cant use my mobile data.
Also, my time is off a few hours
I tried rebooting, calling, texting, but the time is still the same!
Maybe because the data doesn't work???
Please help,
thanks
edit: when i click 2g, a E appears, but it works. Just kinda slow......
Actually H is 4g it is just another way to represent it. It stands for HSPA+ Which is TMO's 4g network as long as you are in a HSPA+ area you will have 4g if not you might be in a hspa area then you have 3g. The E stands for EDGE TMO's 2g network. CM7 and other ROMS that are based off of 2.3.5 or2.3.4 have this issue. Also A2dp (or bluetooth audio) Does not work. Eaglesblood 2.0 has the same problem. Oh and the stock LG froyo camera wont work on those roms yet either. There are two fixes the first is a hard reboot which is done by holding vol up and power at the same time while the phone is on. The other is to download a app that backs up your APN. Good luck
Charlie
