Root G2x rooted ROM--hanging-- any ideas? THANKS
daKINE792
I have an LG G2x tooted on 2.2.2.
I just did this:
Flashing CyanogenMod
Method via Recovery
  1. Download the latest version of CyanogenMod. Optional: Download the Google Apps for the device.
  2. Place the CyanogenMod update.zip file on the root of the SD card. Optional: Place the Google Apps .zip on the root of the SD card also.
  3. Boot into the ClockworkMod Recovery.
  4. Once the device boots into the ClockworkMod Recovery, use the side volume buttons to move around, and either the power button or the trackball to select. Optional: Select backup and restore to create a backup of current installation on the LG G2x.
  5. Select the option to Wipe data/factory reset.
  6. Then select the option to Wipe cache partition.
  7. Select Install zip from sdcard.
  8. Select Choose zip from sdcard.
  9. Select the CyanogenMod update.zip. Optional: Install the Google Apps by performing steps 7 - 9 again and choosing the Google Apps update.zip.
  10. Once the installation has finished, select +++++Go Back+++++ to get back to the main menu, and select the Reboot system now option. The LG G2x should now boot into CyanogenMod.
Now my phone refuses to boot. It hangs on LG boot screen. Any Idea how to fix this?
THANKS!
