Accessories g4 quick circle case stand?
what is better?
  • quick circle case with silicone case as a stand
    Votes: 0 0.0%
  • cheaper quick circle case with no wireless charging
    Votes: 0 0.0%
  • Total voters
    0
akelly90
Hi everyone. I just wanted some advice about getting the lg g4 quick circle case. I really want to get this case but the only thing i would like to have for it is a stand. I used to have a wallet case for my old phone and it was great because i could adjust the stand at different angles but it doesnt need to be as exact as that.
I just want the quick circle case but also a way i can use it as a stand.
I watched a review of the quick circle case on youtube and someone suggested that you can use a silicone case (the one she used was a case called vena) to put on the back of the quick circle case so it gives added protection and the front cover won't go all the way back so you can use it as a stand.
Does anyone think thats a good idea or does anyone have any other suggestions. I'd love to hear it as i want to get this case for my phone pretty soon. Thanks.
Also i would like to have the wireless charging feature and i know there are cheaper options i can go for without the wireless charging so if there are no other possibilities then its an option.
I didn't know there were foldable chargetd so going to check those out as it would be better for traveling. Do you have a link to one I can look at? Mary
Yeah there's a few but a bit more expensive like i said earlier.
Heres one:
Qi-infinity™ Folding Qi Wireless Charger , 3-coils Portable... http://www.amazon.co.uk/dp/B00OP7PTMI/ref=cm_sw_r_udp_awd_JQC3vbRQ9Q0VT
I opted for pretty much the same as you were thinking of going for but different colour case as i thought that would be the best option for the wireless charging to work properly for the g4. I just hope the quick circle case can be just as good as a stand :/
