Hi All,
I have alsmost the same problem....I have rooted my phone and have now the recovery mode from HD blog....it's was working fine.
So I tried to get the galaxhero rom installed
I did the following steps:
1)...Reboot in recovery mode (Volume down + both Call buttons) and choose "Nandroid backup" to save a backup of your current ROM just in case.
2)...backup G apps
3)...Then, choose "Wipe data/factory reset". The phone will reboot in recovery mode again.
4)...Choose "Apply sdcard:update.zip" (second menu entry on the recovery screen)
5)...Restore Google applications ("Restore G.Apps")
6)..."Enable root (su)".
but then enable root failed!!
anyway I went on further with reboot system
it rebooted till the "android HD logo" showed up and then suddenly the screen went off and it seemed like my phone went off....so I went back to the recovery mode and did the following steps:
wipe data
restore backup
restore G apps
enable root su....but again enable su failed!!
Again I choose reboot system, and when the reboot came again to the "android HD logo" ...it stuck there and stayed looping
First...why do I still see the android HD logo again...because I did a wipe!!!!
Second...How can I get my phone working again!!!
Please any help will much appreciated
Thanks
Yassin
2)...backup G apps
wipe data
restore backup
restore G apps
Thanks
Yassin
