Galaxy 2 t mobile bottom lights
The four lights ,menu,home,return and lookup lights up sometimes but not always, have to hit power button and then thay might come on.
I ran a test on mine setting the Display duration on for 10 minutes and the Touch key light duration to always on. They worked without a problem. I'm using the Jellybean 4.1.2 ROM distributed by t-mobile and only install-able through KIES or Odin. What ROM is your S2 using sjharrison? and if you also installed the Jellybean update I did, did you factory reset after the installation?
