Help Galaxy MMS problems - O2UK
carthesis
Since i updated the ROM to the MoDoCo 1.1 build, I've noticed that I'm not getting MMS messages - I get the notification, but whenever I try to 'download' the attached multimedia file, the download fails.
I did a factory reset after applying the ROM, and put in the APN settings for WAP and MMS separately. The MMS one is:
APN: wap.o2.co.uk
Proxy: http://wap.o2.co.uk
Port: 9201
Username: o2wap
Password: password
Server: http://mmsc.mms.o2.co.uk:8002
MMSC: as above
MMS proxy: 192.113.200.195
MMS Port: 8080
MCS: 234
MNC: 10
APN type: MMS
Auth.: None
Anyone got any ideas? I've not been able to find time to phone O2 to check the settings i must admit. If anyone is on O2 can someone check for me?
Cheers.
APN: wap.o2.co.uk
Port: 9201
Username: o2wap
Password: password
MMSC: as above
MMS Port: 8080
MCS: 234
MNC: 10
APN type: MMS
Auth.: None
Cheers.
That should be called o2 wap, Proxy should be 193.113.200.195, have nothing in "Server:", mms proxy should be 193.113.200.195 and should be set to internet and mms
Nope. Tried that - still nothing. It basically tries to connect (you see the 3G icon flashing with the white arrows a few times), then just gives up.
Grrr...
2
1. O2 wap which contains wap and mms settings and set to "internet and mms"
2 O2 Web which contains o2 mobile web settings and set to just "internet"
I rang customer service who emailed me the following settings as far as they are concerned and there is just 1.
Thank you for your recent handset enquiry regarding handset settings. Please find your settings details below.
GPRS WAP & MMS
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering O2 into the settings that the letter O is selected and not a zero.
When entering the following information do not press Save until told to in the instructions.
  1. Press the Menu key
  2. Tap Settings
  3. Tap Wireless controls
  4. Tap Mobile networks
  5. Tap Access Point Names
  6. Press the Menu key
  7. Tap New APN
  8. Tap Name then tap the text box and enter O2 Pay Monthly then tap OK
  9. Tap APN thentap the text box and enter wap.o2.co.uk then tap OK
  10. Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
  11. Tap Port then tap the text box and enter 8080 then tap OK
  12. Tap Username then tap the text box and enter o2wap then tap OK
  13. Tap Password then tap the text box and enter password then tap OK
  14. Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002 then tap OK
  15. Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
  16. Tap MMS port then tap the text box and enter 8080 then tap OK
  17. Press the Back key
  18. Tap Access Point Names
  19. Tap the dot next to your new APN until a green dot appears next to it
  20. Press the Back key four times to return to the standby screen.
We hope this has answered your question. Please note that replies to this email will not be actioned.
If you need further support please visit Mobile guide - Mobiles & Tariffs - O2
To buy accessories please visit Accessory Hub.
For more information on our latest products and services please visit Entertainment - O2.
Coipu,
They worked.
I suspect Rasta's settings would have sorted it out too if i'd noticed 193 instead of 192....
*mental note* Pay more attention in future.
Thanks guys.
