kreamkrackers
Hey Guys!
I have what I think is an issue with the GPS on my Galaxy Nexus that I hope someone can clarify for me.
When I use GPS Satellites alone to pinpoint my location (meaning turning off the option to use data sources such as Wifi and mobile networks) I NEVER get a hit. The GPS icon in the top left when in Maps or Navigation or even My Tracks doesn't even flash.
I called Samsung Support and they said that in order to use GPS you MUST have the Wifi and mobile networks feature turned on at all times.
Surely this isn't correct. To make it even more odd, I downloaded various GPS testing apps such as GPS Status, GPS Essentials and GPS Test and they all pinpoint multiple satellites, then when I go into maps, it then works but only until the phone is switched off!! When turned back on it goes back to square one.
Am I going mad? Surely the whole point of GPS is to pick up satellite signals itself. I totally understand that the Wifi and mobile networks feature would enhance the accuracy, but to not work without it? This would mean that If I were stuck in the desert with no Wifi or mobile mast (unlikely I know), then I would not be able to pinpoint my location.
Do I have a GPS fault? Could anyone test this to see if it works for them?
Thanks in advance guys.
