galaxynexus1
Hello Android Forums! I know this is quite a long post but I'm really hoping that someone out there can give me some help. Just yesterday I finally received my new unlocked version of the Galaxy Nexus from an online retailer and its the Canadian version of the phone. The reason that this became an issue to me was that I noticed that I am currently on Android version 4.0.1 and from what I've heard the most recent version should be 4.0.3 for the Galaxy Nexus phones. After several clicks to check now on my phone state that this is the current version (which I know is not true for ICS) I found out that apparently there are several variations of the software that is installed on the Galaxy Nexus GSM phones. The problem however as I understood it is that the version of the software that my phone has (Yakjuux) isn't updated by google directly but rather by Samsung. After much more reading I was able to find that what seems to be the best option for me is to change my phone over to the Yakju version which as I understand it is updated by google directly. So here are my questions:
1) If I understood the problem correctly and it requires these actions to be taken to resolve the updating problem then is there a way to backup the phone so that if there's a problem I can revert back to the original configuration?
2) Is there a fairly user friendly way to update this to the Yakju version that is updated by google automatically?
3) Does this requiring unlocking?
4) Will this void my warranty?
5) I've also read about different radio versions, what one should I update to if I will be using this phone primarily in the USA?
6) Are there different hardware configurations for the Galaxy Nexus GSM phone or is it all the same internals regardless of carrier or geographic location?
FYI I'm not sure if this information is useful or not but on the box the model of the phone is listed as GT-I9250TSDTLS . Thanks in advance for any help you can provide!
