Is it just me or has Samsung forgotten about the LTE i515 3 pin pogo dock. Haven't been able to find it on Amazon
OP... you can get it here. I've ordered one. Just waiting for it to show up. It's a Samsung one too, not 3rd party.
Samsung Google Galaxy Nexus Desk Stand #EDD-D1F2BEG - Expansys USA
From the linked page:
WARNING: Product NOT compatible with VERIZON edition
I was slobbering all over the place for a Nexus horizontal dock, UNTIL I found Capta:
Capta Tripod Mount SmartPhone and iPhone Holder and Tripod Mount CAPTA
Capta not only makes a great horizontal dock, but a vertical dock, at ANY angle, and it's also a smartphone TRIPOD mount. It's less than half the price of the Samsung dock, it works with virtually ANY smartphone and it lasts forever.
Sure it doesn't have the little pogo pin thing, but do I really need that for $90 or so? Nope. Instead of the dock, I just plug my Nexus in at night and put it on my Capta as a bedside clock while it charges overnight.
Thought you might be interested in an alternative![]()
WARNING: Product NOT compatible with VERIZON edition ’Galaxy NEXUS i515 or Sprint Galaxy Nexus.
I wish there was a 3 pin pogo desktop dock for the verizon galaxy nexus =[
I wonder if the dock will fit the VERIZON edition, because the size of both of them aren't that significantly apart
According to Phonearena the width difference is only 0.02 (LTE Galaxy nexus being thicker)
EDIT: I stand corrected, it wont work Desk Stand (landscape dock) not compatible with Verizon i515 - Samsung Google Galaxy Nexus Vehicle Mount Support Forum - Expansys USA
I'm almost positive those expansys docks do not work with the verizon version. The i9250 nexus has a slightly different thickness than the i515 due to the battery/radio. Expansys tested one of those docks (I think car) and confirmed that even though the pins are very close to lining up, they are not a perfect fit and after you plug it in they kind of work their way out.
I think these are the ones I was remembering, definitely testing GSM pogo docks with cdma phones:
Nexus I9250 accessories NOT compatible with Verizon Nexus i515 - Samsung Google Galaxy Nexus Support Forum - Expansys USA
Using the gsm version in a cdma dock might work better because the gsm version is thinner but trying to squeeze the cdma phone in a gsm dock is a little harder. I REALLY want a car dock but i thought the expansys testing sounded pretty definitive that a cdma phone in a GSM dock does not work.
I'm glad I didn't hesitate to buy one for $90 when Samsung had them on their website. I use mine everyday and love it. IMO, $90 well spent. I tried other types of docks but like this one the best. I use it to stream music through computer desktop speakers at work everyday. On 4.04 works perfect.
Confirmed. I use the extended battery only with zero issues.Do you know if it works with the extended battery? I have not seen anywhere confirm this. Thanks.
Awesome! My family has two GNs (one with the extended battery and one without) so this would have been a deal breaker. +repConfirmed. I use the extended battery only with zero issues.
