confuzzled
My Nexus stopped charging properly last week, it has been charging albeit very slowly. It starts with the battery indicator with the Lightning Bolt inside, then goes through a few cycles of charge then back to the Lighting Bolt Battery so I have been leaving it on for 12 hours straight. Now I now its broken when it comes to charging but I noticed there was a green battery symbol were the charging indicator is (as it is burned into the screen) when I was on a white page (internet or messages) Is this a low battery indicator or should it not be there?
Thank you.
Thank you.
