Help Galaxy Nexus Problems/Issues.. Need Help.
D
Deleted User
Guest
Lately my VZW GNex has been restarting at least twice a week and lately the lock screen music widget takes a while to respond. For instance, when a song is playing and I hit pause on the lock screen, it doesn't respond for like 10 seconds. It does the same thing in the notification tray too. Any ideas or tips to help my solve these issues? Thanx.
What sorts of things have you tried so far? Basic things to check/try:
- Pull the battery for a few mins, and restart, see if that helps
- if any apps were installed, try uninstalling them to see if it helps
It sounds like there's an app or something hanging in the background, causing it to respond slowly. Mine did that at times with Lets Golf if I didn't exit out normally.
Also, I would assume you're stock / non-rooted? Just checking
Worst case, depending on if you've backed up everything, might want to do a reset on it, load the basics, see if it continues.
