Galaxy Nexus radio
VeryEvilAsh
Member
I'm highly Disappointed with this phones radio. Going to return it tomorrow. My Thunderbolt always kept a 4G connection and I have yet to see it on the Nexus. Any recommendations. I heard the Rezound's radio was decent.
I'm right behind you. The radio is just like it was on my Charge, SUCKY. This thing can't hold a candle to the Motorola radio or the Rezound radio. I've been in the same places with all these phones and the GNex just can't hold a 4G signal like these other phones can.
ICS or not, great display or not, if the radio is bad it ruins the entire experience IMO.
I had the Rezound and it was better than 'decent', it was great.
I have had problems with both 3G and 4G data. Called VZW Tech Support and found out that there are other people with the same problem. My advice would be to give VZW Tech Support a call. The more people who report an issue, might put more pressure on them to come up with a solution.
FYI, the problems have been logged into their systems with a "Priority 1" status according to the second tier tech support rep.
Hang in there a little longer. Hopefully they will have a solution for us very soon.:)
