Galaxy Nexus Storage Setup
D
Deleted User
Guest
Everyone complains that the Galaxy Nexus doesn't have a removable SD card, okay. What I am wondering is since the phone is marketed as 32GB, is that just the internal storage, the size of the pre-installed SD card, or the combined size? The main reason I am asking is because with my Incredible, there is the internal storage as well as the SD card. The SD card has way more space than the internal storage, therefore that is where I install all of my music. Unfortunately when I plug my phone into things like a car radio through Micro USB, it doesn't see the music. Will I have the same problem with the Gnex, or am I in the clear as far as using USB to charge and play music in a car?
The Galaxy Nexus doesn't have an SD card, period. The internal storage is the only storage on the phone, so your car music player problem should be solved.
