Galaxy Nexus Watering Hole
Almost done flashing a rom....
.... on my Xoom.
Hey, its a start :)
Now if I can find something I like for my nexus to flash :(
I promise! And you're awesome!
I was wrong. They are in Hi-fi stereo LOL
Grrrrrr. Was gonna hang out with friends and they just cancelled. I'm dressed and was all excited for a night out. Now I'm just sad. :(
You haven't found any for your nexus????
Not that I really liked. Perhaps another look is in order :)
I did notice a few hiccups with the team eos ICS nightly 27 and that is, a few photos made it over from the wipe. Music and movies that I have on my card is MIA, when I first loaded music, my albums showed up and then a split second later, google music popped up. Perhaps I should sign in? The camera / camcorder don't work, but HDR camera + does. I don't use the camera on this thing anyway.
Maps is NOT installed, but that is a simple download I think.
I poked around a bit and found the overclock settings... max is 1.7ghz and change :eek:
Not sure if my 4g radio is trashed or not. Wifi is strong.
I heard the latest build will allow me to mount a thumbdrive (perhaps an external HDD?)
Anyone having trouble with their Market? :/ I've got just under a hundred apps installed, give or take, but when I go to "My Apps," I see 27 installed, 13 not installed (though those 13 are in fact all installed), and the others are all missing! I don't have any updates listed, though I know some of mine have updates ready - when I search for them, I see the app in the search results, and it says it has an update. Rebooting seems to do nothing. Anyone got ideas for me?
was gonna play some poker and friends cancelled right before i drove over. now i'm supposed to go play pool at a bar with a bunch of people (not nearly as fun as feeding my poker addiction)
For Nova Launch users, there's a new version available - ver 13. It now has infinite screen scrolling! Nice! Now if he'd just add more screen transition effects, and a 'random' option, too!
just tried infinite scrolling on the home screen and the dock and it wasn't working for me - yes it would scroll infinitely but it would also randomly add extra homescreen and dock pages and select the blank pages as default.
the cool thing about the new nova launcher for me is ability to edit the icons for folders!
I'm using Airdroid to try to transfer files from my wife's DX2 to my computer. It connects with no problem. On the computer, I click the "files", then select the folder (or files) I want to copy, either click on the "copy" button on the airdroid page or right click and choose "copy". However, when I go to my computer's file explorer, it won't let me click on "paste". It is grayed out. It doesn't matter whether I right click the file or folder on the phone, or choose the "copy" button - same thing. What am I doing wrong?
I am trying to copy via 'export', which looks like it may work, but I really just want to use the 'copy' process. Help!
On your computer, you need to check the select all box and export. It will then put the files in a zip and dump them in your download folder on your PC. At least thats what happened when I transfered 80+mb worth of photos (would not do video, however) last night.
Odd controls. I would rather: control A, control C then control V in a folder of my choice on my PC
Awe what are we, chopped liver? :p
And I'm rockin' a new kernel tonight! Thought mister should know =)
Whelp, just had a fun experience. Flashed AOKP 19 and everything was smooth. Tried to change my wallpaper with WallBase and all of a sudden, I lost my softkeys and kept having System UI crash. Ugh had to do a battery pull and mistakenly booted into bootloader and not recovery. Well, I had to reboot and other than my wallpaper having changed to the stock one, things seem to be working well. Guess I should go ahead and do another backup now!
Edit: seriously, am I dumb enough to try applying the same wallpaper and expecting different results?!?! :confused::o
I guess that certainly is the definition of insanity...:rolleyes:
