Galaxy Nexus Watering Hole
correct, it may not go into the details when it is charging. even without a screenshot, when its unplugged, click on the adroid os and bring up the details... what does it say for CPU total and keep awake?
Just edited my last post :) took a screen shot for later. I know it's not heavy usage but compared to other 4g phones the fact that it doesn't die overnight while idle is very good step in the right direction.
Ok. I have tried to search this forum before posting, but I couldn't find an answer, so I am hoping you can point me in the right direction. I will say that my search gave me many results from the epic thread ;-).
it seem that every email I get with images, doesn't resize. There is no zooming out, just scroll right/left.
Am I stuck here? Something I just need to get used to?
I just checked my wifes droidx and it had pinch/zoom capability, plus some +\- buttons.
Thanks for any help you can provide.
I think its something we have to get used to.
All I care about is that it works. Thanks BB.
I hope to pick up both the charger and extended battery tomorrow.
I love the charger. It holds the phone portrait or landscape. Just not with a case on. And it has the Y cord so I was able to multi task!
Well finally got back to Darth Victorious after lunch.
With the drivers installed already and the necessary files in their proper place from the first time around, unlocking took literally a minute, maybe two.
Rooting was a bit longer because I decided to go the clockworkmod recovery way this time around, for easier romming later on.
Does anyone else with keep awake issue have lightflow? I wonder if the led alerts are causing it - I know they shouldn't but with a new OS it could be possible?
I think I noticed a slight improvement when I turned off NFC.
But I suspect it‘s something we have no control over yet.
Interesting I just noticed regarding my ss's above. Notice how the awake times seemed to me more while on 4g NOT on WIFI. During that time on 4G I barely used the phone I was in church. hmm... maybe the keep awake issue is related to the 4G (or cell) radio?
Yeah I'm not seeing that. About 30% is the cutoff for me where the whites look white and the graininess goes away.
You going to return?
Mine's right in this region also. So I think this guys brightness tweak will do the trick as Auto seems to be JUST below that level unless I am in a brighter than average room.
I dropped my nexus on hardwood floor yesterday. Well actually, knocked it out of my hand. I almost had a bowel movement. :o
It was fine when i picked it up. :cool:
I took a 1080p video on I-95 yesterday using the car dock, and it looks amazing. Very happy with the car dock and video
I think I'm going to do that too. Volume buttons is driving me crazy.
Just so everyone knows... The people at Diztronic claim that the volume button thing is a freak thing. I don't totally know about that since it seems like more people here are having problems than not. But they offered to send replacements to anyone having a problem with the volume button. I emailed them and they responded in like 5 minutes.
As a question... is anyone having the problem with the regular battery back, or is it only the extended battery?
I actually didn't even try it with the regular back before cutting up my case. Also, I heard people saying that the regular back fits with the extended battery, but with mine there was definitely NO CHANCE that was happening. Was that just a rumor or did someone actually fit the regular back over the extended battery?
