jbdan
Extreme Android User
Google bought me lunch.![]()
hah that is awesome! :thumbsup:
Just go into CWM and wipe data/factory reset. It knows what to do. I like to always make a backup of my internal storage on my PC in case anything goes awry
Also wipe cache partition then go to advanced and wipe dalvik cache
So if I select wipe data/factory reset from CWM, it won't delete everything on my virtual SD card?
After that, I can restore my nandroid backup, right?
I've been researching this too to no avail. I thought in the Hong Kong presentation the soft buttons disappeared so you could use the entire screen when playing a video. Would only make sense.
HELP
Uuummmm - what did I do......I have a screen that says ODIN MODE and has a start arrow with an android figure under it and says it's downloading and DO no turn off target!!
How the hell did I manage this and how do I make it go away????
Are you plugged into USB on a pc? ODIN is a utility for low level firmware phone restore on samsung devices.
HELP
I'd honestly just do a battery pull -- see if that gets you back into regular android.
Does keep returning there after a battery pull? That should just be a preboot mode of sorts. Not sure how you would end up there though??
This dude had similar issue and seemed to be from faulty ROM load.
Stuck in ODIN mode!!!! - Android Forums at AndroidCentral.com
Ummm...yikes...no clue.
I'm talented like that - that's how I managed it.![]()
Well I tried downloading and installing this mod:
1% mod With or Without SoftKey Mod NOW! - RootzWiki
Supposed to give your battery stats in 1% increments and add the search soft key at the bottom.
When it rebooted, though, I had no status bar and no soft keys!
Thank goodness for CWR backups.
Need to be on a deodex'd ROM for that although I thought you were, so not 100% sure on that one. I know that is the problem if you lose the status bar and soft keys though.
Seems your talents aren't TOO unique! Must be a girl thing??
http://androidforums.com/samsung-galaxy-nexus/463901-help-me-odin-mode-accident.html
My friend...if you ever get to the point where you understand female logic, please let me know. I'm an electrical engineer that specializes in control systems, logic, and programming...however, the logic that females use baffles me and I have yet to crack the coding system God used when he created them.
That was my thought also, but thought he was on Revolution which should be deodexed.
You dont sound like a jerk. At least not to me. Even with the bookmark i have to zoom in on the screen and then find my last read post, the app remembers that for me and is sized to fit on the screen. And i dont type in landscape so the screen isnt great in the browser for me.
