Help Galaxy Nexus Web Browser Keyboard Input
nzm
Hey, just wondering if there is a way to enable the predictive language input when using the web browser. I need to used a web based email for work, and so really need this feature on when replying to messages. Also has anyone had problems when using the text selector on the web. As I've made several typing mistakes, I need to go back and correct these manually, but when I try to get the arrow in a particular place, it tends to move around manually, which makes it almost impossible to use.
Also I've had quite a few other issues, so does anyone know if there's a way to contact google / sumsung with these problems?
Thanks
It is a bug. If you root and install a 4.0.3 ROM, it's fixed. Or, you can wait for the official 4.0.3 rollout and it'll be fixed.
