GALAXY note 2 Sidebar
Hamza93
Hi everyone
i just bought note 2 . im more than happy with it . i showed it to my cousin . and i think he accidently removed the sidebar . i want to know how i can put the sidebar back .!! i can find it anywhere . . here is a picture of sidebar
i hope u will reply !!
regards
hamza
Ok, I cannot seem to bring this window up. I long pressed the back button and nothing. Also, Setting/Display/? Multiwindow I dont have. ATT version
If you root you can install a mod to include every app in the multi-window panel. It's pretty spectacular.
Settings/Display/Multi Window
I have been searching for a resolution for this issue and found none. Thank you! I just found that I disabled/turned off the Multi Window :D. I thought my phone is broken :P. I'm such a noob on Android and I'm pretty glad I did the switch. This is the best android forum! :)
