Hey guys,
I bought my Galaxy Note (GT7000) a few months back. Just today, it has started acting very weird, so was hoping for some help!
Basically, I left it in my room to charge, and when I came back it had shut down. I tried restarting it over and over again but to no avail. Also tried taking out the battery, SIM and SD card and then putting them back in and restarting. Nothing worked.
For some reason it started up after a while, and said that the battery was at 1%, I plugged it in but it would not start to charge. At that point it opened up the Task Manager automatically and then restarted. Since then it has not stopped restarting. I can get into my phone for about 3 seconds max, before it restarts. I've plugged it into charging and it's constantly vibrating, but I don't know how much of a charge it's getting given the constant restarts.
At this stage it's charging (I see the green battery graphic with the little white circle animation) but as soon as I turn it on and it gets to the lock screen, I can see the task manager opening in the background and it restarts again, argh!
The only other thing I can remember is that I installed the 'Speed test' app to check my WiFi speed. I would try and uninstall it but there is no way my phone will stay on for long enough for me to get in there and do it.
