That's why I've set up my phone to unlock when it sees my face.
Menu -> Settings -> Security and lock screen -> Screen lock -> Face
It generally works well although it doesn't like strong back-lighting. If it fails to recognise you, it will then ask you for your PIN instead.
Its slow though. It takes too long to not recognize you before reverting to PIN. At night time I found it was taking 5 seconds + everytime I wanted to use it.
Plus its not very secure. My colleague unlocked my s3 with a photo it me displayed on his iPhone screen.
thanks .. problem resolvedWelcome to the forum hellobye.
If you go to settings, security and untick make passwords visible it should sort the problem.
