LOL ironass, hes used the wave phone to take a photo of his sg2.
joshi* that usage screenshot is what mine looks like really, display using most power, its when your OS is chewing the juice something is going on.
for a start, get rid of Advanced Task Killer and Juice Defender, they would chew more juice than what they claim to do.....secondly, if there is a samsung center near you, just take it in and get them to test it. i had same issue and they confirmed it was a dud battery sucking a higher than normal voltage, still waiting for it though so cant tell you yet of the difference.
the temp is normal, getting hot under load is not uncommon, its bad when its getting hot when NOT under load or so hot you cant touch it. mine go REALLY hot after about 1/2 hr on plants n zombies, but i could still hold it.(p.s. the CPU is near the camera, hence that warm spot)
1 days use to me is a stock SG2, hell i only get about 10-15 hrs out of my dud battery with everything off and doing bugger all.
lastly, ive turned my network to GSM only, stop it from searching and changing in auto mode, i reckon it helps life too.
I've been fiddling with the battery settings, disabled widgets, wiped the phone, bought several popular battery saving apps and tried every trick in the book, my experience has been that the number one drain on my phone (and i'm talking a change from ~2mA to ~200mA) is auto sync.
Coming from the BB world, it's frustrating to have to choose between having a decent battery life, or receiving emails in a timely manner.
I've done well with my battery life without any need for a juice defender.
SC20120115-201819 by JimmyGalaxy, on Flickr
