Help Galaxy s2 Gallery Problem HELP!
Everytime after I use kies air to my computer, all the gameloft HD games intro videos appear in the gallery like this in the photo
I wanna see of others have the same problem or only me and I really hope someone can help me remove them from the gallery without delete the files or any other way. thanks!
Android's gallery scans your SD and picks ALL the media content in there. That means it grabs videos and pictures used by other apps and shows them to you.
There is a way to stop that: you make a file (it doesn't matter what type) and name it ".nomedia" (without the quotes), with that the gallery will no longer pick up that particular folder (and any subfolder within); the only downside is that the app that created the folder -in this case, your games- probably won't pick the folder as well, so you might find some conflicts with that.
Thanks for kindly replying me. I showed all the hidden files. There are .nomedia files inside the game folders. but they still show in the gallery. i think its the kies air application that causes this problem. this is the second time of this problem. i tried a way to solve this problem, it is deleting the game videos then download again.
But i wish there is another better way.
You could always try to set your own .nomedia file just to be sure. After that, extract the SD and insert it again (forcing a new scan from your phone) so that it can recognize the file and get them off your Gallery. I do remember that I had to re-scan the SD before folder that recently had their .nomedia file put in them to disappear from the app.
Good luck with your issue.
Yes I have exactly the same problem, it is caused bt Kies Air that does not respect .nomedia files. Hope somone will come up with fix soon.
