Help Galaxy S2: Help me understanding it (please!)
wildsibyl
Hi!
I bought an used-but-great-looking Galaxy S2 aweek ago.
It is my first smartphone, first touch one, and first android.
I'm doing pretty well with it tho, considering.
Being an used smartphone, has been modified by the previous user.
Changes mainly consist, as he said to me, in "having removed from the phone social hub, Game, Samsung App, and just adding the guideapp and another app with the extra settings."
He also told me he had included a 2GB SD and a much more powerful ROM.
In other words, all the changes he made were done to have a longer battery life.
Since then, i did all I could to personalize it, but I got in some problems, some that I have understood and solved, some that I didn't but solved in other ways, and some that I really don't know how to deal with.
The one that buggs me the most is that I can't send music (but I can send images!) to other devices using Bluetooth. I click on the song and I have all the options but that.
(my doing is: USB-> take songs from the PC and put them in the 'G / Samsung / Music /' folder)
I searched in the folders of the phone to understand it but I found that doesn't work like a computer, and I really don't know where to search, or where to putthe songs to make that damn option to pop up.
I'll attach what pops up when I connect my GS2 to my PC.
Can some one help me with this? pleeease!
Open the music app, press and hold on the song. There should be an option to share music via bluetooth there. You probably have a different music player to me if you have a different ROM, but I'm pretty sure that option is there in the Android default music player too.
already done that, but as I said the option isn't there.
I would upload a screenshot but the home+lock button only shuts down the mobile..
default music player? how/where can I find that?
thanks for your answer, BTW:)
It's most likely the app that's installed on your phone.
Try downloading and installing "Bump" from the Market. You can just bump two phones together and swap files between the two.
Edit: oops. Doesn't support music :(
to all of you, but the spammer one ;)
I have, as usual, found a way out!
the problem is still there but I have found an app left by the previous user called Root Explorer, that is on sale in the market app. (didn't have to pay for that, yay!:D)
in other words I went to the songs in the sistem (finally some computer-like folders!) and the option popped out!!!
I know I could have changed the launcher, and probably solve the problem with a new one, but I really like the skin I have now :rolleyes:
New problem: how can I make a screenshot if the two buttons toghether don't respond??
love u guys:)
