Okay so I know there are a fair few threads about this on here already but none of the solutions seem to work so I thought I would try my luck by describing my issue exactly!
When I connect my (new) Samsung Galaxy S2 to my computer with Kies (version 2.3.2.12054_20) running on it, it doesn't connect. When I first plug it in it says "MTP Initialisation" then "MTP Completed" and nothing happens on my computer.
When I go "Settings-->Wireless and Network-->USB Utilities-->Connect Storage to PC" then connect my cable, Kies says 'Connecting' but then comes up with the dreaded:
I have looked up other solutions but they don't seem to solve the issue:
USB debugging is unchecked.
I have tried taking out the SD card - same issue.
Restarted and reinstalled everything in every permutation...
Any other suggestions (for a non technical person)? - I just want ICS on my Galaxy S2!
More info:
Samsung Galaxy S2 (Black) - Not Rooted
Model Number: GT-I9100
Android Version: 2.3.5
Baseband Version: I9100BOKJ1
Build Number:Gingerbread.BOKK1
Reconnect the device in Samsung Kies (PC Studio) mode.
Current connection mode not supported by Kies. Check the USB setings"
More info:
