Help galaxy s2 probs
peteq
Hi all - new to this forum so pls be patient with me!!!!!!!
Does any clever person know the answer to these -
1) where can i get a list of that the icons at the top of the screen mean;
2) is your internet slow eg youtube vids take ages to load then only shows 5/6 secs and gives up
Thx Pete
Are you on wifi or mobile? If you are on mobile connection check what type of network your are connected to, H is the fastest and should have no problems, 3g is also good, you might have problems on E or G they are the slowest, particularly G.
