Help Galaxy S3 LTE got white screen
yurids
2
0
I've bought a Galaxy S3 LTE (GT-I9305) and it got with white screen after a battery discharge, and it ONLY turns on at Download Mode.
So it has one week that I'm trying to reinstall it's firmware with Odin, but always appears the message "There is no PIT partition", and the Re-Partition checkbox is not selected.
I had bought my phone from France, the Orange's one.
Ps. Now the battery is at 0% and it doesn't recharge, I've tried many ways, with diferent cables, but none of these worked.
This way I can even go to Download Mode.
Make sure you have Samsung Kies or the Samsung USB Driver installed on your PC.
  • Download and Extract: Odin3 3.04.zip - 457.11 KB to your PC if you don't already have it.
  • Download and Extract: Param_Bin_I9305.zip - 612.14 KB to your PC.
  • With your Phone Switched Off, press and hold: 'VOL DN' + 'HOME' + 'POWER' to enter Download Mode.
  • Connect your phone to your PC via USB Cable and start Odin.
  • Check your phone is connected by seeing if a COM Port in a Blue box is present under ID:COM.
  • Press the 'PDA' Button and select the 'Param_Bin_I9305.tar.md5' file you extracted from the Zip Archive earlier.
  • Press the 'Start' Button and wait for it to finish flashing. If successful, you will see a Green Box with 'PASS!'.
  • Wait for your phone to reboot then go to your Dialer and press: *#06#. You should now see your IMEI and your Data Connection will be back.
Upvote 0
BEST TECH IN 2023
Smartphones
