Jfalls63
Android Expert
Reflashing the firmware should have returned you to fresh out of the box condition. The data you restored with Kies should be the only thing added.
Rooting is not for everyone depending upon what you are trying to accomplish. To get rid of/disable bloat so you don't see it or have it pester you for updates or run in the background, I would recommend Package Disabler Pro from the Play Store.
Its a paid app but worth the low price. It works as a device administrator to disable apps that normally you can't through the app manager.
It has a automatic option that will take care of most bloat with one click.
Also the ability to let you disable or enable things as needed.
Glad you got it sorted, happy to help.
