Help Galaxy S3
Hi there, I have a problem I cant solve, there is little info about my case as well
My battery is draining very quick lately, I thought at first that its the battery itself that is old and bought a new one, but the problem still persists
I performed the factory reset lately and still it doenst hold the batery
Even being charged using the phone it drains and looses battery
Could someone suggest a solution please?
Thank you in advance,
Get some info about what is using your battery:
1 - Settings / battery - post a screenshot
2 - tap on the graph near the top to expand the graph and add new detail below - post a screenshot.'
#1 will show show screen and apps... how much battery taken.
#2 will show at the bottom: mobile network strenght, wifi, awake, screen-on etc. These can provide some clues. If device is awake for long period with screen off that's a clue to investigate wakelocks. If gps on, might be worth turning it off. Weak phone signal can be a problem.
