Help GALAXY S5 IS STUCK IN UNREPAIRABLE BOOT LOOP
A
Android Question
Guest
My SM-G900F is stuck in a boot loop.
When this happened, I Tried to do a factory reset plus cleaning cache in recovery. However this didnot fix my problem so I decided to reflash using odin, so i download the official rom and installed it but again same issue happened. After so much research and headache I installed CWM and did a kalvic, factory reset + format system a few times then I reflashed it afterwards. This seemed to have made the boot loop even worse since I doesn't pass through samsung galaxy s5 powered by android logo. That where the boot loop happens.
So overall I have tried
Reflashing ROM about 5 or 6 times using odin
Factory reset
Clean cache + kalvic
FORMAT system and boot
Hitting it hard as much as possible without breaking it.
Pulling the battery out for about a trillion times
Current result:
Headaches 24/7
Thanks
Are you getting a Pass in Odin? That is weird, it should fix your issue. Are you sure that it is the correct firmware? Also, check to see if it is a good download.
I did get passes. I also got my firmware from sammobile.com
Im pretty sure its the currect firmware But Im not sure if its a good download.
What does that have to do with the boot loop anyways?
I've seen this boot loop issue mentioned several times with the S5, even after flashing the firmware. What people say fixes it is to factory reset & wipe cache after flashing via odin. Hopefully someone else can chime in.
After each reflash I did a factory reset and clean cache. Afterwards it just goes to the samsung galaxy s5 powered by android logo. Thats where the boot loop happens.
Can cyanogenmod 12 fix this issue?
Please don't re-post once members have replied to the original, as it only causes confusion for both those attempting to help now and anyone with a similar issue in the future.
If the OP's phone can't be unbricked with that tutorial, it is probably toast.
I have one comment on Odin to the OP, did you use the correct version of Odin for your S5?
I wish I had a £1 for every time I've read that. ;)
There are, currently, 40 different models of Galaxy S5 and over 3,000 firmwares for them. See, 40 Galaxy S5 models - Dummies Guide.
1. Which carrier are you with?
2. Which country are you in?
3. Were you on Android 4.4.2 or 4.4.4 or 5.0?
4. Which firmware, exactly, are you attempting to flash?
model: SM-G900F International adreno snapdragon
Carrier: 02
Country: United Kingdom
Android os: IT was on 5.0 when it happened, then i downgraded to 4.4.2 with same results then again reflashed to 5.0
Firmware: i tried tons. this was the latest one i tried. but same results
Can other devices do the trick like note 3?
Or does it have to be a working s5?
Both guides state...
" Insert the microSD card inside a working Galaxy
S5 SM-G900F mobile phone
"Insert the microSD card inside a working Galaxy S5 SM-G900F mobile phone."
PLAN B...
Take it to the nearest Samsung Service Point and plead ignorance and blame the Lollipop update. Might work!
PLAN B...
I swear I'm gonna go nuts.
I knew I shouldn't have gotten the s5.
Can some shop just repair it or something?
BTW wont the samsung service point fix it themselves or i dunno i bought this thing without warranty?
Whats ATF JTAG?
Thanks
PLAN B...
Can't cyanogenmod 12 fix my issue?
Could u give me the link for it?
ummm, it isn't the S5's fault that you broke it.... don't blame the hardware for something you did. I suggest you just go to the repair center and say "the OTA did something and now it is broke"....
okay!!
But Technically I didn't break it. Boot loop came out of no where.
Same situation on my fiancé g900f.
Bootloop out of nowhere, and set warranty bit kernel. It boots to "galaxy s5 powered by android" one second then reboot.
Could you tell me what you see in download mode? Custom binary and system? This happened one month after the lollipop wifi ota. Never touched anything on that phone. Every odin flash is a pass! But Bootloop remain with boc7 lollipop and kitkat
What I see in Download Mode:
ODIN MODE
PRODUCT NAME: SM-G900F
CURRENT BINARY: CUSTOM
SYSTEM STATUS: CUSTOM
REACTIVATION LOCK(KK): OFF
KNOX WARRANTY VOID: 0*1 (4)
QUALCOM SECUREBOOT: ENABLE (CSB)
RP SWREV: S1, T1, R1, A1, P1
SECURE DOWNLOAD : ENABLE
UDC START
Downloading...
Do not turn off target !!
(Thanks)
