Help Galaxy s6 edge plus Android system content hidden
A
Android Question
Guest
I'm not sure how it happened, but I have a message on my lock screen that reads "Android System content hidden". When I press on the notification, and then unlock the screen, I'm taken to the available WiFi connections screen. I've clicked on every connection, and on the "More" menu, but there isn't an option to unhide the content. Any thoughts or suggestions would be appreciated. It's not really a major issue, it just bugs me.
The settings/sound & Notification (Shown or Hidden) did not fix this issue. Message says "ANDROID SYSTEM content hidden" it is only displayed on the lock screen.
did you ever get this fixed? I'm having the same issue.
I'm having the same issue. Here is a screenshot of my lockscreen.
I may have found a solution. I raised the limit on mobile data usage. At the time before, I had it set to turn off my data after 6gb and I was at 7gb ish. I manually overrode and to "turn data back on" and those wierd lockscreen messages came up. By raising my data limit to 8gb, it stopped the lockscreen message. This is my lockscreen now. Hopefully this helps
I have unlimited data on my phone plann, but set a limit on data anyway, and this has not solved my problem. Each time I come into an area where i connect to wifi automatically, this message sits on my phone until I unlock the screen. When I open the message it just takes me to my wifi list. How can I make it stop? It's annoying and I'm sure getting notifications each time I come and go is wearing on my battery life too.
