Help galaxy s6 FRP LOCK
  • Thread starter Thread starter ANNA C
  • Start date Start date
A
ANNA C
Guest
can anyone please help me with binary blocked boot frp lock did hard rest and nothing
If you've factory reset your device with FRP enabled, you need to enter your Google account information to use the device.
There may be times when you wish to perform a Factory Data Reset on your device.
Note: FRP is enabled on your device if you are using Android 5.1 OS or higher, your device initially released with version 5.0 or higher, and you have a Google account on your device. It is highly recommended that you have a secure screen lock enabled.
Since your device is protected, you'll need to unlock your screen if you need to do a factory reset. This ensures that you or someone you trust is doing the reset.
Important! If you reset your Google account password and need to do a factory reset, you will need to wait 72 hours after changing your password to reset your device. For security purposes, you can't use the related account to access the device after reset if the password was changed within 72 hours.
To perform a Factory Data Reset when FRP is enabled, follow these procedures:
  1. From a Home screen, touch Apps > Settings > Backup and reset > Factory data reset.
  2. Touch RESET DEVICE and follow the prompts to perform the reset.
  3. When the device restarts, you will be taken through the Setup Wizard again.
If your device has encountered an untrusted reset, hard key factory reset, reset from Android Device Manager or Samsung Find My Mobile, or repair services that include resetting the device’s software, without first removing the account:
  1. Verify connection to a Wi-Fi or cellular network.
  2. When prompted, you will be asked to verify the previously used Google user-name and password. Follow the on-screen prompts.
  3. When prompted again, enter your Google account. You can enter a new Google account or the one you previously used.
http://www.samsung.com/us/support/answer/ANS00042882/997379756/
First off I have looked at other relevant threads for quite some time for help but can't seem to find exactly what I need. I tried rooting my phone using Kingroot. After it finished my phone booted up but it gave the error"KERNEL IS NOT SEANDROID ENFORCING Custom binary blocked by FRP Lock". I tried to factory reset my phone but to nothing. I have downloaded the stock firmwareappropriate to my devices modelfrom Sammobile. I even extracted the .tar.md5 file from it. The phone had been bricked for 4 days now and I need to get it fixed ASAP and by the way the phone is aSamsung Galaxy S6 edge plus
Probably your best bet is to flash the stock firmware with Odin. I think on newer Samsung devices there is a way to turn off the Factory Reset Protection (FRP) but not sure where.
At the bottom of the page where you downloaded the firmware at Sammobile is instructions for flashing.
Can you try flashing again and post pic of error messages?
Only other thing I know to try would be the Firmware Update and Initialization option in the tools tab of Smart switch but you need tho know the device Serial Number to make it work.
This is it
Looks like the errors you get when you try to flash the wrong firmware (downgrading). You could try the Smart Switch method if you have the SN. Should be on the box if you still have it.
Ok, just got to my laptop and opened Smart Switch and let it update and they have changed things a little.
1- Open Smart Switch and click on more
2- Click on Emergency Software Recovery and Initialization
3- Select Device Initialization
4- Enter device info (model number)
5- Enter SN and click OK
Should be able to follow the rest of the prompts from there.
