Help GALAXY TAB WEIRD problem pls need help guys
avancena
can you tell whats wrong with my galaxy tab?
ill try to reset manually but same problems..
i cannot use may tab normally because everytime i tap the screen always appear that notification like this...
can you pls help me guys TIA:(:(
Go in to wireless and networking and uncheck all connection choices (de-activate/disable all wifi and network settings).
Then reboot and reconfigure wifi and networking to get rid of that force close.
Hi,
I keep getting the force close message (maybe once a day, and usually, but not always, when I'm opening the email app), and the reset you suggested doesn't stop it. Any other ideas would be welcome.
Thanks,
David
