Root Galaxy with GalaxHero Rom and Battery
mist3r0
hello guys, I've a Galaxy and I installed the rom GalaxHero, but last few days my Galaxy usea a lot of battery.
TurnOn the phone at 13 o'clock, still in standby, at 21 o'clock the battery was at 55%.
That is completely abnormal. :confused:
I've installed the application "spare parts" and I see that in "Battery History" - "Other usage" it reported running 97%.
So I Installed another program, "Drain-O-Meter", this brings me to the process "System_Server" which uses the CPU to 100%. :eek:
Can you help? the battery lasts me very little, maximum 24 hours in completle standby.
Before we even did about 70 hours!
Please Help me!!
Now the phone is tuonOff in Charging.
This morning I've see the partial wake and only Os Android had used, but very very tittle!
For the Other application the indicator was empity!
At the first time I had GalaxHero, after I passed to Galax0, but I'had a few problem and I returned to GalaxHero.
the step that go below are:
1.[FONT=&quot] [/FONT]wipe
2.[FONT=&quot] [/FONT]apply any zip and Choose GalaxHeroRom
(I choose this because I renamed the file "Update.zip" of GalaxHero rom to "GalaxHeroRom", and the file "Update.zip" of Galax0 rom to "Galax0Rom", so I can change roms whenever I like).
3.[FONT=&quot] [/FONT]restore G.apps
4.[FONT=&quot] [/FONT]Restore LibHGL
5.[FONT=&quot] [/FONT]Reboot
and if I want
6. reboot, turnOn Recovery mode
7.[FONT=&quot] [/FONT]apply any zip and choose
I don't Know, but, when I installed GAlaxHero At the fitst time, I installed GPU, for test, I run "Speed Forge", but it don't work, it is very very slow.
Now, I've installa only the Rom and the library, after installation I've rum "Speed Forge" and it worl very well...it don't stop when you play!
...back to my problema, because battery of my device live few?? :confused:
Thanks, but I did this test.
I'm doing the test again now, see what happens.
Sorry, but if I reboot into recovery mode and do the wipe what happens?
everything will be eraser?
....I've rebbot now, History battery is 80%!!!
I never have this problem with the case!!
of few days the phone have this problem!! turnOn the phone at 9 am, battery at 80%, only in stanby, now battery is at 50%.
The battery time life is OK for you?
After the reboot in the "History battery" of Spare Parts was 80%.
after 20 minutes is 11,4%
thats pretty shocking
try flashing back to a standard rom build and see if you still get the same problem
i know you did before but that is a bit odd
I've unistalled all applications that I had installed, but not unistall the applications that there are pre-installed in the rom.
I've reboot, and install the application one at one.
I seen that an application create me the problem, I've unistalled it, reboot and now the phone is ok!!
For example I've TurnOn al 8 am my phone, I've send 2 sms, and now at 11 am the battery is 98%!!!
Now I'm really very happy!! :D
