lvlln
Member
I've been going crazy the last few hours looking for how to install GApps onto Nookie Froyo (0.68) without using ADB. I figured there should be some simple flashable zip that I can use in ClockworkMod recovery, but that doesn't seem to exist. I tried using the CM7 one with no luck. I tried creating my own using files from an ADB-based guide with no luck, either.
Is there any way to get GApps onto Nookie Froyo without ADB? As you can probably guess, I've spent hours trying to get ADB to work on my PC, because that seems to be the easiest method. I can ADB into my HTC Incredible just fine, but no matter how many times I follow the directions and troubleshoot, the Nook simply doesn't show up as a device.
I imagine this is a path that others have followed before, so it puzzles me as to why there's no guide or, again, a simple flashable zip.
