OTA update from Verizon 7/14 and here's what's new on the bad side:
* All WAV files play 1.5 seconds and then endlessly loop, regardless of file size or storage location;
* Cell service drops frequently;
* Can't set individual task notification sounds - they're either ALL on or ALL off. I used to be able to have just ringtone and text messaging notification on and all others off;
* Battery life is about 50% diminished;
* App icons vanish from home screen upon USB connection.
What's new on the good side:
* Mobile hotspot works much better/stable;
* Doesn't auto-launch the pain-in-the-@ss Motorola app on my PC when USB connected;
* Phone reads 242MB more on the SD card available space than before;
* Flash on ESPN is almost completely fluid, not jumpy anymore.
