GB sense home screen
thorthunderblt
Can someone if possible please post a pic of their home screen since downloading GB. I thought that it might revert back to sense (or w/e) from launcher pro, but it didn't. I am just really curious to see what it looks like. If there are any differences or what not.
I haven't got access to get a screen shot right now, but if you've got launcher pro installed, it's super easy to switch over and see the sense screen, then switch back to launcher pro (unless you've checked the box that made launcher pro the default action, that is).
Just go to Settings->Personalize.
You'll see a dialog that says "Complete action using" with a select list that includes Launcher Pro and HTC Sense. If you click HTC Sense, your homescreen will be auto-magically transformed to the Sense version. Do it again (simply touch the Personalize icon at the lower right to bring up the above dialog again) and pick Launcher Pro to get back to your unspoiled, completely independent Launcher Pro screen. The only thing the two seem to share is the options that you've set on common widgets.
If you downloaded the ota from verizon, none of your settings would have changed. if you had launcher pro setup, it will still be set to that. The actual sense home screen hasnt changed except for the pull down menu.
If you want to check sense yourself, download the app Home Switcher and you will be able to switch from sense to launcher pro & vice versa
I did the OTA update yesterday and everything seemed to work fine, except for the voicemail notification issue. I restarted my phone today and it has reverted to the Sense dock. My Launcher Pro dock is gone and I can't seem to find the app anywhere in the app drawer. I unistalled it and reinstalled it from the market and its still not visible anywhere. I still have the docks and icons downloaded in the Gallery folders but how do I set up the dock again? I also lost my custom clock, and now I can't remember which app it was from, as it seems to be missing from my app drawer also. So much for the OTA update not messin with your screen set-up. WTF
ETA: wonderful, I can't find my BobclockD3 app either. Several of my apps are missing in my app drawer. If I go to the market, Bobclock says its "installed", but I can't locate it anywhere on my phone. Long press on the widgetlocker setup screen won't produce it either. Like it disappeared.
