Droidster
Member
If you do not want to root, go to app manager in settings and disable the ones you do not want.Also, I hear a lot about bloatware on the stock phone, and I definitely do see a lot of apps I have no interest in. Any recommendations about apps I can disable/delete with no problem? I don't want to go crazy on my own and start disabling everything in case I disable something that's actually important.
The other post with wallpapers.. you can set those in settings as well... icons and such can be found in different launchers on the playstore... its easy to root and is fully reversable.. check out the How to threads
