Root General Rom/Mobster Rom Question
Tejer
Hi all, I am posting this thread here because for some odd reason I have posted like 5 different posts over the course of 5 hours in the Mobster Rom V thread that is in the Ziggy & Mobstergunz forum and every single one disappears as if they were never even posted after like 20 minutes. :mad: If anyone knows anything about this, feel free to educate me on what the heck is going on.
Now, my question is this. I am not too familiar with the black themed apps, like the google play app. Does anyone know if it will auto-update when a new version of play comes out? If so, will it still be black themed or does it revert back to stock look?
Yes they will return to stock after updating, as far as I know there is no way to prevent Google Play from auto updating. Just push the modified apk if it happens.
Thanks for the reply on that, i'm glad to know. I asked because I'm not a huge fan of the black theme but it will do. I get a weird graphical hiccup when I replaced the black themed one with the stock one, where everytime I check 'my apps' section a black line temporarily comes horizontally through the screen.
Another issue i've experienced:
Anyone else on the Mobster 2.25 rom or any other experienced their ringtones/notification sounds resetting upon a reboot of the phone?
My posts got deleted also. Not just happening to you. Which sucks because my battery was draining badly on reboots and usage, weirdest thing as it was working with Harmonia hours earlier.
Ugh just charged completely then wiped battery stats. Rebooted and am at 93%, booted into recovery immediately and am now at 86%. Probably restore harmonia.
Some of my posts were deleted too. Someone must be doing extreme cleanup on that thread. Anyway, to answer the OP, the graphical glitch and the notification sounds resetting were issues, but it is fixed now in the newest version (2.37). I'd highly recommend you update to the latest Mobster ROM.
