Generic tablet wont boot up.
gazza192
Hi being on a low income i decided to take a chance and bought a cheap dud tablet. It is a chinese one but has no manufacturers name on it. When i turn it on i get the bird in the top left hand corner then it flashes android on the screen but nothing else. Can anybody help?
You must reinstall rom
1. Download the Rom_xxxx.zip or 7zip or rar (search for "rom" which fits with the tablet)
2. Unzip the file
3. Copy the Script folder to your microSD root
4. Insert microSD in the tablet
5. Connect the Power cable to the Tablet and then power it on
6. Wait until the on-screen display reads remove microSD or SDCard
7. Removed the microSD or SCCard.
8. Turn on the tablet
