Geniatech Enjoy TV
Hi all, I have prepared a new update.zip file specific for latest 20120529 ICS release.
This package will:
-change fingerprint line (for more apps on market...for example: Yamgo Tv)
-reset Play Store (data and cache)
-let us access to our own market (many thanks to gboijhpok and kwuw4sale)
-add 3 files .jar in "framework" folder (for more compatibility with some apps...for example: Tweetdeck)
Here is the link: update_fingerprint-tweak_and_market-resetter_for_ICS-0529.zip
Install as usual (in recovery mode, renaming it as update.img) or using the inbuilt
Upgrade app...then access directly to your own market.
Just thought I would give a big thumbs up to the support at Geniatech. After lots of emails I have been able to sort out most of my problems. Except one. Becasue I am using my old crt TV that doesn't support 720 or 1080 I won't be able to watch TV through it. I can record it and watch it at a later date because the playback does get downsized to a format my old tv can handle. Bugger, this means the ATV is not what I was wanting.
So does anyone in Australia want to buy a pretty much brand new ATV3000 with a MyGica T119 usb tv dongle?
What's your offer?
Hi to everybody!
I tried to find information about problems with updating to android 4.0? I have 310 model and tried to upgraded it and fail. Now I do not know what to do, the box does not show anything. Do somebody know how to reanimate my box? Thank you very much.
Hi to everybody!
I assume that you have had a look around the Web for help.
I don't know your tablet, but I found this here that may be the same as yours:
tab310 is corrupted
on the Yarvik Support Forum site
Quote: "Did you have this problem right out of the box, or did the problem showed up after you used it? However, the problem should be solved by doing a hard factory reset. Just hold power+home+back for 5 seconds while the tablet is turned off and then follow the steps on the screen."
Further the forum talks about reloading the firmware from a SD card but I did not follow through. You may be able to find specific forums and ask for help.
Hi,
Ive now upgraded to 4.0 build 20120529 and applied the update above ( many thanks for that !! ) . Is there a way to view files on an external harddrive as when i plug it in no matter what file explorer i use i cannot find my usb drive. I plan to watch movies on it but am currently struggling !!
Thanks in advance and thanks for the help with the patches supplied !!
Hi,
Have you tried ES File Explorer...click 'Favourites' button and you should other drives.
Hi,
So ive realised Es file explorer does pick it up , but it seems when i copy a file to the external harddrive and plug it into the box it recognises it and i can see the files , but then the external harddrive seems to corrupt you can no longer see the files or pick it up, and then when i plug it back into my pc i am forced to re-format it.
Has anyone else had this problem ?
Hi,
Last week I bought ATV1000 and starightway upgraded to ICS4 online.Everything is
ok I can access google play.Flash palyer is 11.
I cannot able to play online movies and streaming(example-
Rakhtbeej (2012) 1 - Watch Latest Videos Online Free)
I can paly this on my mobile which is ICS4.
Looks video is loading but before it starts it throws out to main screen of ATV1000
Can anybody suggest the solution and or try on your ATV1000 following links.
Thanks.
I can watch this on my mobilt http://www.filmshowonline.net/videos/100334/
this I cannot able to watch on mobile www.startv.in/video/?1_1_Krishna-villa-is-renovated-
Okay I'm new here, so going to edit my own post about the XXXX29 version. For anyone having any issues with the network I suggest give your antenna a wiggle. This latest update ending in 29 is just what I have been looking for. I have updated flash to 11, ES file explorer works like a charm streaming from my WD live, Netflix, & Plex is back to its true form audio sync is spot on with everything I throw at it. That leaves me with 2 questions.
1. to whom is it that I need to send out a donation cause I have the media center in my Geniatech ATV1000 that I have wanted for ages and I haven't even tried NES or other game ROMS...my poor ps3 getting dusted.
2. Does anyone know if USB is fixed so I can skype with a cam to my family back in the US?
Cheers
Hi,
Thanks.
I can watch this on my mobilt Rakhtbeej (2012) 1 - Watch Latest Videos Online Free
I use plex and have added unsupported channels ice streams and let me watch this. They are decent quality some are very high quality. Also there is an Ice Stream.apk floating around that works a treat as well. Good luck. and Hope this helps.
@Gorjo - i use the box mostly for streaming 720p-1080p (5-8bg file). dont use the box for browsing, cos its painfull...
@szemo77 - i would love one of this ATV1200-Enjoy TV Dual core. is this the fastest/most powerfull on the market at the moment?? btw, where to get one of this from? could not find any supplier(
This package will:
I keep getting a failed update when I try the tweek (software not signed)
Further when I try to un-rar or unzip I get a broken file/file corrupt error.
I was going to recompile it.
Can someone check and re-upload. BTW I have downloaded it a number of times just in case.
Pls download the file. Rename the entire file and also change the file type. The file should now be called ' update.img' (image file now) . Put this update.img onto an sdcard and load it on your machine. Switch your machine off. Press the 'reset' button at the back of the box with a paper clip or pin and while pressing it , press the power button. This will switch your device into update mode and keep put buttons pressed while you see the screen starting the update process. Leave the buttons when it starts. Wait for few minutes until it updates and restarts itself. This will only update related parts on the box and not overwrite the entire firmware.
No need to unrar or unzip the file.This procedure applies to all updates.
Usual disclaimers apply !!! :D:D:D
Hi enviro8, I've just checked and I've verified that the update file in mediafire is perfectly working
(no need to re-upload).
I don't understand the reason of your issues...:confused:
You could try to download it from another PC...
Addendum
Following gio965's comments, I will try to download on another PC and try again.
Yes, I have tried several times to update and downloaded a number of times using both the inbuilt update app and the reset/power button methods but I still get a failed update with the following message:
E. Failed to verify whole-file signature
E: Signature verification failed
I un-rared it so that I could extract the components and use gio965's method to generate a new update.zip (post #1123 above).
During the un-rar I got the following messages:
1 CRC failed in 'META-INF\com\google\android\update-binary". File is broken
2 Data error in 'system\build.prop'. File is broken
3 Data error in 'system\framework\com.google.android.maps.jar'. File is broken
Can someone check and re-upload?
I would like to share another issue regarding my box (..yes .it is mentioned in my profile). I am using a plasma screen to watch videos. This screen is 2nd generation made in 2004 and has 1080i res thru DVI. I would not part with it due to picture performance and being built like a tank in Japan costing 12k when sold.
I had to take this box to my friends place for a demo . I put the display settings to 1080p at his house when connected due to capability of his screen. It worked okay with everything. Upon getting back home I could not get any picture. I realised the display settings need adjustment. I used component and hdmi both to get picture as before but none worked. I decided to use the dreaded reset button but still did not get any picture. I always pressed the reset button while the box was 'on' but the box did not reboot /restart at all. I only got picture if i updated with some patch which it did showing update screen. It rebooted after updated but still gave no picture.
I fixed this by connecting the box to my computer monitor which has 2560x1440 resolution. I got the picture once i connected it to my PC monitor with hdmi and changed the display setting to 720p. Connected to my Plasma screen later and got the picture finally.
I conclude that reset button does not reset the display settings to 720p as from the factory (pls note I update it to 0529 ICS from 2.3.4.). I still had all the apps i loaded afterwards. Pls share if I am not resetting the box using another method.
