Help Getting a Dx replacement... can verizon transfer everything to the replacement?
Gareee
Looks like I have a dead pixel issue on my camera.. when I get a replacement, can that transfer all my settings and everything over, or do I need to downbload and install and setup everything all over again?
I'm using launcher pro, and setting up all 7 home pages again takes a LOT of time.
As far as I know, you will need to backup everything yourself and restore it. You can use Astro file manager to back up all of the apps to SD card. You can also backup the LauncherPro settings in the LancherPro "Preferences" menu. After you get your new phone, swap SD cards and restore everything. LauncherPro will not restore your widgets, so you will have to do that manually.
Thanks.. sounds like that'll be a pain then. But better to know in advance, so I can back everything up.
You can use appbrain to save your apps. You can also use back up assistant to back up your contacts.
