my phone is rooted, and i am wondering how i can use titanium backup to restore all my old settings and apps on my new phone?
someone advised me that it can be done...havent tried it yet but...
waiting for some serious discussion on this so im subscribing![]()
Just do restore all apps & data. I used it a lot when I had my Dinc. I actually had better luck with MyBackUp but TB should work. You may need to do some manual work after but it still saves a ton of work
when u say data, that also includes settings...like brightness level, music profile set to 3-d mode etc?
I did it by backing up all the apps I wanted. Then just copied over the titanium folder that it makes of the backups on the sdcard to my desktop. Then onced I got rooted installed titanium I placed the folder back in the sdcard and restored.
Well I just used it on my replacement DX and it worked like a charm. Only have to redo the widgets. Here what I did
Swapped my sdcard to the new phone
used Astro to install and run the root app I had on the sdcard
once rooted
reboot
downloaded TB from market
(Make sure to select"problems" button and let it download busy box, also make sure it it recognizes you license key)
Restore "All apps and system data"
Reboot as soon as TB is done
Done!
It looks just like before and has all my setting also (except widgets.)
