I just loaded 893 and rooted my bionic. I'm ultimitly trying to load .901. But when booting into recovery I get a the ! in the triangle. So I loaded Rom manger and I get the same thing.
Not sure what is going on.
I was following this process:
Flash the 5.5.893 fxz file with rsdlite. Follow the directions here. How to Flash 5.5.893 from Rsdlite
reboot
Then use tehsusenoh modified releashed and forever root file here. R3l3AS3DRoot_Windows_V2.1 - modded zergRush - Minus.com Option 2
reboot
copy the 5.9.901 file to your external sd card
power off the phone.
Boot into stock recovery by holding both volume up and down and then the power button. When the menu appears volume down to get to recovery and then volume up to select. the select install update from sd card and select the 5.5.901 file. When it is done you should be on 5.9.901 rooted.
reboot
reboot
